BONDO, OR NOT TO BONDO ;
model40fan Friday, 12/16/2011
I HAVE TRIED BONDO, NITRA-STAN, BUT BY ACCIDENT I HAD TO SAND OFF SOME PLUMBER'S PUTTY... IT IS HARD AS A ROCK... SANDS, BUT SLOWLY... SEEMS TO BE A FINER COMPOSITE... SEEMS TO BLEND TO THE METAL SMOOTHER THAT OTHER PRODUCTS...
EconoCarl 12/16/11
Smitty, will the plumbers putty bond two parts together? Or is it just used as a filler?
model40fan 12/16/11
carl, it bonds the castings to each other... chops, filled windows, it won't stop the axles from spinning or sliding side to side, if you use it to attatch them...not like j.b. weld... i will try scratching /marring the axle surface where the p. p. would be ?...
tastelikedirt 12/17/11
Is J.B. Weld usually used for bonding metal body parts together?
model40fan 12/18/11
can't speak for all but ... yes...
where j.b.weld is a 2 tube epoxy mix, plumber's putty comes in 1 tube, take it out cut off what you need wrap it back up, slide back in the tube. knead the chunk till lighter grey, pack it into the spot you want it...
it is not heavy... a hot dog size tube weighs 56 grams...hope it helps !
