Building my CCC Hot Rod...
Hey Guys!
It's been a while since I've done a build-up, so, I thought I'd do a thread on the '32 Ford that I am putting together for the Crew Chief Challenge race....
http://i1074.photobucket.com/albums/w407/critterwerks/20160823_090124_zpslzujqnvh.jpg
I'm starting off with your basic '32 Ford
http://i1074.photobucket.com/albums/w407/critterwerks/20160823_093903_zpsz1ltp7h7.jpg
I like to drill the rivets in a drill press, so I can hold the car in a vice
http://i1074.photobucket.com/albums/w407/critterwerks/20160825_085614_zpsq54nep1d.jpg
This is,what it should look like with the rivets drilled...just drill deeply enough to pop the car apart
http://i1074.photobucket.com/albums/w407/critterwerks/20160823_094432_zpsblv8qdpf.jpg
These are all the components of the car, but since this all weights about 38 grams, the windowsing and the interior won'y be used
http://i1074.photobucket.com/albums/w407/critterwerks/20160825_085702_zps7yfhqdjg.jpg
To get the axles out, I generally just cut the tabs off, but you can gently pry them up if you want to retain them
http://i1074.photobucket.com/albums/w407/critterwerks/20160825_085758_zpshxw6ud21.jpg
If I were going to do a simple wheel awap, these are the parts I'd be using. But, I think I'll be doing something a little different for this one
http://i1074.photobucket.com/albums/w407/critterwerks/20160901_085551_zpsrjtewiof.jpg
I first glass-beaded the body to remove the paint...so, I can better see what I'm doing
http://i1074.photobucket.com/albums/w407/critterwerks/20160916_195946_zpskym5rvp7.jpg
These '32 castings are too wide, if you look at a real car, so, I'm going to remove a little material, right down the middle. I'm using a fibre glass dremel cut-off wheel. A word to the wise, this is not a job for a first-time customizer...this casting is really thick in spots and not the easiest to cut in half
http://i1074.photobucket.com/albums/w407/critterwerks/20160916_200922_zpsv19yzama.jpg
But, with a little patience, you can make a nice cut down the middle. You can also do this with a hacksaw if you prefer...personally. I like the cut-off wheel. I should say here...Please where eye protection when doing this!
http://i1074.photobucket.com/albums/w407/critterwerks/20160916_201029_zpsah53lqus.jpg
The two halves, being head together...it's looking better already
http://i1074.photobucket.com/albums/w407/critterwerks/20160916_202416_zpsmdkxin62.jpg
It wasn't really possible for me to take a pic while I was JB Welding the two halves back together. I was carefully holding the two halves together, looking at the windshield and rear window openings while the JB Quick Weld sets up
http://i1074.photobucket.com/albums/w407/critterwerks/20160916_202439_zpshinfoejg.jpg
Two years ago, I made up resin '32 Fords as prizes for the first CCC race. I still had a chassis laying around, so I thought I'd use that (it's kinda the opposite of what most hot ridder do in real life...this is putting a '32 body on Model A rails...I hope to put a Model A body on '32 rails some day! ). I'm not sure what the engine is from...a donar from Traction Event, molded and cast in resin.
http://i1074.photobucket.com/albums/w407/critterwerks/20160916_202553_zpsoffyz57b.jpg
As you can see, this combo is easily light enough to make the 35 gram weight limit (those are just stand-in wheels...the real wheels to come later in the week)
I'll do some clean-up on the body and install the wheels next weekend
Here ya go...
http://i1074.photobucket.com/albums/w407/critterwerks/20160917_193134_zpskjvfuapw.jpg
The car on the left is the same casting, so you can see that I took over 1/16" out of it.
http://i1074.photobucket.com/albums/w407/critterwerks/20160917_193119_zpsozmvhuzs.jpg
I also removed the tab that the stock engine sits down over, to get the new engine in there
- Perfect, thank you sir! What does this modification allow you to achieve? — delta6
- If you look at a real '32, the HW casting is too wide...I'm just trying to make it look correct! — 72_Chevy_C10
- Great work !! — VoxxerRacing
Here's a pic of a real '32...
http://i1074.photobucket.com/albums/w407/critterwerks/32-Ford-Hiboy-3W-Coupe-04_zps2kag5gu4.jpg
You can see, they are pretty small/narrow
That is AWESOME work! You should instagram this too. #therightwaytobuildcoolcars
(A # i have never used personally. LOL)
Maybe a side by side picture, or before & after, of that body modification just so we can see the difference of the narrowed body?
Thanks buddy!
Nice step by step process.
