Chassis build now being tracked
You may notice now that the chassis/build type of a car now appears in the listings and on profiles. I went through this past weekend and updated each car in the league. There are 3 build types:
MP - Metal/Plastic
MM - Metal/Metal
PM - Plastic/Metal
Simple enough, right? I haven't added any options to filter by build yet so you'll just have to check the column as you search through cars.
I'd say my updating of car profiles is 95% accurate, so if you find a car that is listed with an incorrect build type, please post and ask so I can check it out.
The only also mistakes it for plastic...easy mistake to make, I guess.
edit: Mattel's database confirms it...http://www.hotwheelscollectors.com/showroom/checklist/list.aspx?txtSearchString=Ferrari+575+GTC§ion=cc...no plastic chassis 575 GTCs.
Now all you need is "Plastic/Plastic", like the Halloween Phastasm from a couple years ago!
