Customizing and TuningHOT MAIL... Mail van , Way 2 fast base.
  • Jump to last reply
Stocker Way 2 fast ;
The mail.
The "Hot Mail" mock-up ;
'55 gasser grill ... needs front fuel cell.
The chopped mailbox would look good on that base with a single engine out front...
model40fan
hammered one had the jb break loose... back in the someday box...
I like where this is going!  I once did a tilt nose Anglia delivery on a WTFast base. Took the nose off and it fit pretty good.
A 3/8" diameter shaft from a plastic coat hanger, split lengthwise then cut to length as the fuel cell that hides the axle prongs ;
Modded way 2 fast engine / interior, hole drilled through the windshield for induction ;
