Trash Master... '15 turbine time and maisto garbage truck box.
Turbine Time stocker ;
'15 HW turbine time and MAISTO garbage unit... Mock up ;
The "diecast modders" logo ;
After your comments, I sanded 1/16" or more off the bottom edge of the box... To clear DRAG TRACKS finish...
Maybe have the trash haulers series run a 57 g or more limit, as you may use a metal body-metal base combo... and there is plenty of room to hide weight... careful, DRAG TRACKS finish is 1.30" tall !
I saw hole shot at the flee market... he had a couple WILD customs
Hey smitty you know what might make this an even meaner look trash truck? Put the exhaust stacks on. On the sides right where the trash part meets the cab. Just some 2 cents I wanted to throw in.
Smitty, I found one of these as well...couldn't keep it in one piece...easy drilling plastic body and engine.kept the pipes, but lots of choppin on this one. lowered rear axle, smaller wheels, flat bed,
http://i1070.photobucket.com/albums/u495/Squiggy799/IMG_5248.jpg
- Cool...Vehicle Haulers, Take II — 72_Chevy_C10
- cool truck, haven't seen but the one i found on a peg... looks ready for action... — model40fan
- I grabbed one the other day...haven't opened it up yet — 72_Chevy_C10
- The stock ones are pretty quick too — CrzyTrkrDude
Just a thought for this thread...if you a search on ebay for DCP (Die Cast Promotions) truck parts, or DCP Peterbilt, you will find some cool stuff. The trucks are way pricey... $50, just for a truck, no trailer. But, they are really nice 1/64 scale trucks! And a lot of guys do custom rigs, so parts trucks are out there!
http://i1383.photobucket.com/albums/ah305/CrzyTrkrDude/IMG_20150308_085902_zpsbatk2xir.jpg
Found some exhaust stacks for the garbage truck.
MBX Torque Titan. They are flat on the inside. Might glue right on the side.
- been thinking of using leads solder from a spool, can file grooves into them as shields... — model40fan
- check out $1 mini screw driver handles at the dolla store. — model40fan
- Your aluminum axle tubed would be a scale 4" exhaust....might work — 72_Chevy_C10
- Hmmmmmmmmm....... — model40fan
Do we want a "Trash Master Series" ? ... Garbage trucks only ? ...Y or N... weight limit ? _ _ _ grams ...
wheels _ _ _ _ _ ...
http://i1383.photobucket.com/albums/ah305/CrzyTrkrDude/IMG_20150308_130454_zpssothxl0b.jpg
I could be talked into a build..... ( not the vintage orange one. Best find of the day. Got it for a buck!! Man, I feel bad, but I love it when the guy is short when the booth rent is due!!) but definetly the red one for sure. :)
I say, MINI FTE only. (Might help keep the height low enough.) MINIMUM of 100 grams ( make those wheels work hard like in real life.)
Give us 2 months to build. And count me in for sure!!
You know I'd build a garbage truck racer, Smitty...I'm thinking in the 65-75 gram range. They could be heavier, I just don't like going over that much.
Lots of cool trucks out there!
Okay, that is seriously Awesome!
I see a Trash Haulers Series in the works! Maybe include Cement Mixers too!
