Track Building and BuyingWood Plank track base... Dual lane starter
I thought I might make some stuff that could be easily mounted to a 6" x 1" x 6' plank base...
  Here goes, a dual lane, retainer pins starter unit, [3 and an extra screws included], [2] wood screws go through the starter and into the TOP of the plank, [1] screw goes into the END of the plank..
Note the END hole to the right of center, the horizontal 5/16"- 18 bolt lets you screw on another nut till that end is heavy enough to retain the cars [no elastics or springs] ;
Brass handle, a 3/8" stroke starts the cars, pins are 2" apart, the cardboard box is to resemble the plank's position ;
top 2 mounting screws are about 5" apart
a little chrome duct tape, white paint, a dual lane track anchor and 2 short track sections with "pin" holes ;
hmmm.... use an eye screw to anchor the starter to the wood, run a cord through it and tie it around the brass handle... poof ! remote starter...
Rusty
Wow,missed this before.great build!!!!
