Hot Rod base... I Candy
model40fan Saturday, 4/11/2015
Stockers ;
Chunk of Way 2 Fast's roof as a front bumper, it and the I Candy base's front are angle filed to make trapeziodal slots supporting the bumper ... Leave a JB RIVET hole, because drilling later can knock the bumper off...
The '32 Delivery body only needs a little filing at the rear center, lower grill and front sides of the hood...
Rear wheel well hogging to be determined by Gov'ner's wheel restrictions... wheels, tubes and FTE axle to be cut in half ;
Axles ready, bumper installed ready for JB quick ;
Pre-strip mock up ;
Still needs the area over the windshield filed to better resemble a '32 Ford...
The after and before shots ;
Axle slots deepened with a hacksaw and a file, JB Quicked in place and the w/s header re-shaped... Not too much work to get yourself a real Nasty Nancy hot rod...
Looks like with a little filing and sanding the RAAB deuce coupe will be right at home here too ;
