Screw on starting gate camera stand
model40fan Wednesday, 11/26/2014
Taking the staging pix will be easier with this rig... rotate 180 * for down track videos
[2] 2" screws, matching nuts and wingnuts ... 1 1/4"-20 bolt to screw your camera onto, loosening the wingnuts will let you adjust the angle in all directions ;
the plate will bolt to your wooden base with the upright being out board of the plank for smooth folding of the track when stored...
 welded washers to wood screws to make thumb screws, to attach the transfer and secure the support strap ;
installed onto a chunk of door trim ;
loosen the wingnuts and you can swing the camera stud out over lane 2...
