Hot Wheels Metric Labs Raceway
Total length
22'
Style
Road course
Lanes
6
  • Style: Road course
  • Total length: 22 ft.
  • Lanes: 6
  • Built by: GregFoster
  • Added: 10/29/2026
About
Hot Wheels Metrics Lab is a data-driven racing channel built around measuring and ranking Hot Wheels cars. The goal is to take the same care a lab would bring to a physical experiment: collect baseline data on every car, run structured heats and tournaments, and publish the results so viewers can compare their own collections against ours. The channel's first public event is a mail-in tournament on Redline Derby on November 23.
The build started with a plan rather than a purchase. I laid out the track as four equal 10-foot links with three 180-degree turns, so the 40-foot run folds back on itself and fits a compact floor area. The start sits at 45 inches, and the drops are set at each turn: 30 inches at Turn 1, 20 at Turn 2, 10 at Turn 3, and the finish at ground level. That gives a steady drop of about 4.8 degrees on the three lower links, with a steeper 7-degree first link. I drew the layout as a plan and side view to scale so the heights could be checked before any framing.
For testing, I'm using two six-foot folding tables at 30 inches for the first turn height, with cardboard boxes stacked to set the other heights. Once the layout is confirmed, the plan is to build a 2x3 frame that can be adjusted to the exact heights.
The track pieces include the 6-lane Raceway, and two vintage Sizzlers sets, the Giant O and the Big O, both originals. The 6-lane timing system is from Play robotics.
