Quick review of the Fun-Tech-Lab Runsible 1:64 dyno
AbbyNormal Saturday, 7/19/2025
Just arrived five minutes ago unpackaging video later this evening.
First impressions
www.youtube.com/watch?v=2JKFPRr3wdo
EXCITING!  Hopefully mine shows up next week.
StrayDog 7/19/25
Got mine today!
Zizzer_Prime 7/19/25
Still waiting on mine
EnZedRacing 7/19/25
Sorry for the stoopid question...what is it?
AbbyNormal 7/19/25
Sorry for the delay but my iPad had / has a space problem - its a long video so hopefully its processed at YT
youtu.be/2JKFPRr3wdo
  • Subscribed — GspeedR
  • interesting — dr_dodge
  • Hey there, Dr. Dodge I saw on your YouTube comment you asked if these were page motors - I’m not familiar with those — AbbyNormal
  • In theory, if all things were equal and blah blah motors remained the same in temperature and brush wear remained constant: Sorry, in theory you could hook up an multimeter/ammeter and be able to see that faster cars would require less amperage than slower cars. Or as a car broke in over time the amp draw would also reduce. — X2Whiskey
dr_dodge 7/20/25
this is a pager motor.  used in micro charge it up rcs
you can remove the counterweight, (they sell them w/o vibra weight)
4mm x 17mm, pretty small, short duty cycle
and does the drive band drag on the bottom of the casting causing the chatter on the dyno?
  • Not sure where the chatter is coming from but its not the drive belt as they appear to be well recessed. — AbbyNormal
  • Thanks for the info guys. — CutRock_R_Marc_D
How long did it take to arrive after you purchased it?
  • Mine took about 10 days from when it was shipped. FunTechLab provides reliable tracking. — GspeedR
  • ok thanks, I think mine has been lost then, it's been much longer than that!! — Road_Runner_Rumble
  • Mine came in pretty quick, within 5 days — JerryTonya1995
Thanks Abby for the info, update.
Not sure it initially meets your engineering requirements! Understandable!
There certainly needs to be more to it, or otherwise, nice toy!
Cheers,
I finally got mine earlier this week, after ordering it on 3rd June!
Well, after all this time I have found this thing to be marginally useful. The speed has zero adjustability the potentiometer is little more than an on/off switch... the wheels seldom engage properly on the front and rear simultaneously and the rollers are frequently slipping on the belts.
I am not impressed. I will be trying to play with it a bit more but after a few months, I'd say if you haven't bought one don't waste your money...
FredD
  • Fully agree — Dutch_Clutch_Racing
  • I agree totally, only time I use it is if I’m batch lubing a bunch of cars I’ll do a brief run-in on each car. — AbbyNormal
  • I get some slipping back and forth, too. You might be able to tighten down the screws on the bottom to prevent this, or as a last resort, put something between the rollers to keep them from inching together. — SpyDude
I use it to run in the wheel/axles after each treatment, 15 minutes each direction. This pic is at the end of one run, with no significant heat buildup in wheels or axles.
