HalfFast Hearse and Diesel Duty
Picked these up yesterday after noticing that the wheelbase of the '59 Caddy Hearse funny car and Diesel Duty were nearly the same.
With a little work I came up with this:
What color should I paint it?
Then decided to clean up the lines of truck and give it a tonneau cover:
sweet! I hope to have some time this evening for some custom work.
Nice.
Very nice.
Did you add any weight?
a chassis swap, a wheel well hoggin' and new paint... HALF FAST GARAGE is on a ROLL !
Very nice.Did you add any weight?
Thanks Jason, both of these are a work in progress. Still trying to figure out how to attach the body to the chassis on the HalfFast Hearse!
I'm trying to venture out and get some "real" altereds built!!!
try using some alum tubing. Attach it to the body just above the rivet hole in the base and then just screw them together as you normally would. Just make sure the tubing is securely attached. Some of the weighted cars really take a beating at the end of the track.
I try to use screws on all of my race cars. It makes it much easier when maintenance times comes.
paint it the fastest color you can... or,... it kinda looks christmassy as is...
