Homemade Curves
Anyone know how to make a dual lane curve. I need one 180 that has only a 6 or 7 inch radius ? .........Stroller.
Here is something I plan on trying.Older Tyco TCR track from the 80's and 90's.The later versions had a rail separating the cars in the curves.Looks like it will work..Slot-less track so no slot..
I ran a Drag Tracks track set up, with [2] 20" angled sections, 18" transfer, [6] 20" sections of run-out, then [2] 24" JL sections, a 12" orange section, to a HW dual 180* banked "hot curves" turn... for returning the cars to the starting gate...
the cars were too fast for the turn...
later i found and used a JL Daytona 500 set's 180* ... a true 90* track surface, dual 180* turn, fairly tall side rails...
I easily modded the plastic JL connectors to go from DT female to JL...
... gave it to the johnnies years ago...
Here's another option.
http://www.ebay.com/ulk/itm/281915392663
I haven't seen this on eBay very often.
Max Traxxx makes a 90* 2-lane curve...I have one that I'm going to review, haven't even opened it yet. It seems pretty tight corner so putting two of them together might get you a quick 180...
