Redline Derby track changes, specs
I don't have any photos yet, hopefully before Sunday when I have some light, but without that wanted to pass along the specs for the track changes. Here is a rough sketch that is not really to scale.
Overall length is 19.5 feet from front of starting gate to the finish line.
Cars are falling from a height of 3.5 feet. The hill is 5.5 feet long at a 37* angle.
The big change in the track is the transition. At the switch the track is 4 inches off the ground and over a distance of 6 feet drops down to 1.5 inches off the ground. From that point on it is a flat straight away for the remaining 8 feet of track.
So basically you have big hill into gradual hill into straight out. Same starting gate and same finish line.
It might not seem like much of a change but it makes a big difference in terms of heavier cars not flying off the track. The extra decline made for a much easier transition but there is still a straight away. I'm really happy with this update, however slight it may be.
This setup will remain for this season and the next to end out the year.
Pretty much how I have my track set up but a little longer in the flat.
