Removing axles from metal chassis.
Stroller Wednesday, 9/17/2014
I wanted to remove some axles from a metal chassis without damaging the axles so I ground down the metal tabs with a Dremel. Then I tried bending back the tabs with a small screwdriver. Now it looked like the axles were loose but they weren't. I thought about for a while then took the chassis into the bathroom and held it under scalding hot water in the sink. After a few seconds the axles came loose. I don't know if it was because the metal chassis expanded under the heat or the axles just got slippery anyway that's the way weird things happen here at the Stroller Garage....lol
I have good results using really pointy heavy duty side cutters. I guess the hobby railroad guys use em to cut track. They hold an edge and get right in close to cut the tabs.
