Speed on a Budget
Brakefluid_Tracksurgeon Thursday, 1/7/2016
http://i.imgur.com/GNLr3aK.jpg
Does anyone know how to make a fast car on a budget? These are some of the stuff I have:
Drill
Drill bits
Nail filer
1" wire wheel
JB Weld
FTE axles
Graphite
360 grit sandpaper
This might be of help...
http://redlinederby.com/topic/super-simple-68-camaro-mod/2150
redlinederby 1/7/16
If you have to deal with axle length problems, getting some 1/16" tubing from the hobby store is handy. Cut the tubing the width of your chassis. Cut the FTE axle in half and then slide it into the tubing.
  • What specific stores sell them? — Brakefluid_Tracksurgeon
  • hobbylobby here — Stroller
  • I've gotten them at Hobby Lobby too. Local indie stores seem to have them too. — redlinederby
  • Hobby Lobby. even some Ace Hardware stores. They've got alllll kinds of cool materials. Copper, brass, sheets, tubes Angle. Balsa, TONS of s — CrzyTrkrDude
  • stuff. I LOVE just looking through their parts drawers for ideas. ( RLD Brian said it a while back too) — CrzyTrkrDude
You can still sand the wheels in the chassis, and graphite the axles. That and making sure the car travels straight go along way.  On any of the slo-motion videos you can see which cars "hug the rail" and which ones are "neutral" in the lane.
  • if you can find any of my cars, chances are... it's a perfect example of how huggin a rail will slow you down...lol — CrzyTrkrDude
  • Hugging can also be a result of the track too — redlinederby
  • Some of my cars are very affectionate when it comes to the track... — CrzyTrkrDude
  • there is HUGGIE, and his side kick SQURILLY, — fordman
I've never understood sanding the wheels...if anything I think it.s most likely you'd make them less round unless you had a really good system....
How do you cut brass pipes without mashing its ends?
  • Cut-off wheel in a dremel tool — 72_Chevy_C10
  • slide an old non FTE axle into the tube then cut it... — fordman
  • use welding wire to push the cut off axle out... — fordman
  • i have to throw away 10 feet of .023" wire with every spool...9 this summer. — fordman
Finally made my first axle with an axle tube.
http://i.imgur.com/SmYIrhU.jpg
  • bravo... — fordman
  • looks waaaaay better than any I've ever done! CONGRATS! — CrzyTrkrDude
