SPLICING 2 BASES FOR WIDE REAR TRACK
STOCK '55 BEL-AIR GASSER AND ASTON MARTIN BASES ;
'55 BEL-AIR GASSER BASE WITH THE REAR CLIP REMOVED, ASTON MARTIN ;
BOTH BASES CUT TOO LONG... A BEVELED EDGE CAN BE FILED INTO THE CENTER "ASTON STRIP AND '55 SLOT" SO THEY OVERLAP FOR A STRONG J.B.QUICK SPLICE...
BEVELS FILED J.B.QUICKED ;
DUMMY REAR AXLE FOR TEST FIT ;
SPLICED BASE WITH TRIMMED ENGINE / INTERIOR, DUMMY AXLE ;
MOCKED UP ;
.THINKIN' ABOUT GOV'NER's WIDE WHITE WALLED TIRES ON FTE II AXLES...
Wow...Sweet! Nice work...do the cars run well after this surgery is done?Preacher
Amazingly well if you take some time and align the chassis. Not threadjack, but here is my Pro-Stock camaro from the drag car series came in 2nd to Smitty by one point....yes it still stings abit....The red is the camaro chassis, and the black is a TR6 Triumph
You guys are some kind of engineering geniuses!
I'm gonna try it.
not a day of college here,
but I have learned from more mistakes [mine and theirs] than I can count,
I.M.O. buy some $0.10 -$0.25 loose gooses to practice on...[get ones with spare parts you can use after practice]...
the t bird's base is the first that I have done... except for the wheel alignment it is the same job as adding a front bumper.
