Poppa Speed Invitational - HW Dragsters
Saturday, August 8th, 2020
LeagueofSpeed Tuesday, 2/18/2020
Event coordinator
This is the HW Dragster Division of the Poppa Speed Invitational. There is only one style of legal casting for this race: the standard HW Dragster casting. Builds must have the Larger size Rear wheel pictured above.  You've got 5g to play with to get them to 40g. Good Luck Racers!
Please post questions, comments, and other discussion on the main Poppa Speed Invitational thread.
  • Modified entries only
  • 40g maximum weight
  • Hot Wheels standard Dragster casting(pictured above) only
  • Limit 2 entries per Racer
  • HW Dragsters came with 2 different Rear Wheels...Builds must have the larger wheels
  • You may Wheel swap or use the orginals...wheels must be the same size and diameter as the Stock wheels(front and rear) on the HW Dragster...NO AXEL TUBES...solid uncut axels
  • Front and Back Wheels must be same Width and Height as Original Casting...Spokes are fair game
  • Dry lube only
  • These are Modified entries only...Must have Drilled Rivets...Must Have the same size Wheels as the original casting if Wheel Swap is choosen and brought up to 40g
All entries must be received by the host on or before Saturday, 7/11/2020. Racing is scheduled for Saturday, 7/18/2020. Results will be posted on or after that date as is convenient for the host.
Trophy and Bragging Rights!!!
Races will be run on the Quest Speedway track.
HW Dragster Division Sign-Up 32 Teams/64 Cars
1 - League of Speed
2 - Lady of Speed
3 - Speedzilla
4 - Speed Force
5 - Outlaw Racing
6 - MattMan213
7 - Rivera Racing
8 - DVB Racing
9 - 41-14 Racing
10 - ND Racing
11 - Voxxer Racing
